Saving All Messages to the Hard Drive Using VBA
› Developer › Saving All Messages to the Hard Drive Using VBA
Last reviewed on August 29, 2018     161 Comments
Use this code to save messages with the date in the filename, retaining the Outlook file structure.
To save selected messages as PDF files, see Save Outlook email as a PDF
This code sample will save all messages in a specific Outlook folder (and any subfolders of the selected folder) in a folder you select on the hard drive. The messages will be in a subfolder of the selected folder, where the subfolder is named for the Outlook folder you selected.
Note: if you select a subfolder of a top-level folder, for example, a subfolder of the Inbox, folder named Inbox needs to exist in path on the hard drive.
The filename format is yyyymmdd_hhmm_subject.msg, as in:
20100422_0319_Inquiry.msg
The filename is set using this code:
StrFile = StrSaveFolder & StrReceived & "_" & StrName & ".msg"
Filenames are limited to 256 characters in length, with the subject trimmed if its too long.
Note that it can take some time to run if the folder contains a lot of messages. Allow about 2 seconds per message, or about 15 minutes for 400 messages.
VBA Code
Click in the code area, press Ctrl+A to select all, Ctrl+C to copy then paste into Outlook's VBA editor. Instructions on using the editor are at How to use Outlook's VBA Editor
Option Explicit
       Dim StrSavePath     As String
Sub SaveAllEmails_ProcessAllSubFolders()
    Dim i               As Long
    Dim j               As Long
    Dim n               As Long
    Dim StrSubject      As String
    Dim StrName         As String
    Dim StrFile         As String
    Dim StrReceived     As String
    Dim StrFolder       As String
    Dim StrSaveFolder   As String
    Dim StrFolderPath   As String
    Dim iNameSpace      As NameSpace
    Dim myOlApp         As Outlook.Application
    Dim SubFolder       As MAPIFolder
    Dim mItem           As MailItem
    Dim FSO             As Object
    Dim ChosenFolder    As Object
    Dim Folders         As New Collection
    Dim EntryID         As New Collection
    Dim StoreID         As New Collection
    Set FSO = CreateObject("Scripting.FileSystemObject")
    Set myOlApp = Outlook.Application
    Set iNameSpace = myOlApp.GetNamespace("MAPI")
    Set ChosenFolder = iNameSpace.PickFolder
    If ChosenFolder Is Nothing Then
GoTo ExitSub:
BrowseForFolder StrSavePath
    Call GetFolder(Folders, EntryID, StoreID, ChosenFolder)
    For i = 1 To Folders.Count
        StrFolder = StripIllegalChar(Folders(i))
        n = InStr(3, StrFolder, "\") + 1
        StrFolder = Mid(StrFolder, n, 256)
        StrFolderPath = StrSavePath & "\" & StrFolder & "\"
        StrSaveFolder = Left(StrFolderPath, Len(StrFolderPath) - 1) & "\"
        If Not FSO.FolderExists(StrFolderPath) Then
            FSO.CreateFolder (StrFolderPath)
        Set SubFolder = myOlApp.Session.GetFolderFromID(EntryID(i), StoreID(i))
        For j = 1 To SubFolder.Items.Count
            Set mItem = SubFolder.Items(j)
            StrReceived = Format(mItem.ReceivedTime, "YYYYMMDD-hhmm")
            StrSubject = mItem.Subject
            StrName = StripIllegalChar(StrSubject)
            StrFile = Left(StrFile, 256)
            mItem.SaveAs StrFile, 3
        Next j
        On Error GoTo 0
    Next i
ExitSub:
Function StripIllegalChar(StrInput)
    Dim RegX            As Object
    Set RegX = CreateObject("vbscript.regexp")
    RegX.Pattern = "[\" & Chr(34) & "\!\@\#\$\%\^\&\*\(\)\=\+\|\[\]\{\}\`\'\;\:\<\>\?\/\,]"
    RegX.IgnoreCase = True
    RegX.Global = True
    StripIllegalChar = RegX.Replace(StrInput, "")
ExitFunction:
    Set RegX = Nothing
End Function
Sub GetFolder(Folders As Collection, EntryID As Collection, StoreID As Collection, Fld As MAPIFolder)
    Folders.Add Fld.FolderPath
    EntryID.Add Fld.EntryID
    StoreID.Add Fld.StoreID
    For Each SubFolder In Fld.Folders
        GetFolder Folders, EntryID, StoreID, SubFolder
    Next SubFolder
ExitSub:
    Set SubFolder = Nothing
Function BrowseForFolder(StrSavePath As String, Optional OpenAt As String) As String
    Dim objShell As Object
    Dim objFolder '  As Folder
Dim enviro
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(0, "Please choose a folder", 0, enviro & "\Documents\")
StrSavePath = objFolder.self.Path
    On Error GoTo 0
ExitFunction:
    Set objShell = Nothing
End Function
How to use this macro
  • How to Save Email in Windows File System
  • Import Messages from File System into Outlook Folders
  • OWA: Save Messages to My Documents
  • Save a Message as HTML and Delete the (Annoying) Folder
  • Save email message as text file
  • Save Outlook Email as a PDF
  • Saving All Messages to the Hard Drive Using VBA
Saving All Messages to the Hard Drive Using VBA was last modified: August 29th, 2018 by Diane Poremsky
  • Save Messages and Attachments to a New Folder
  • Use VBA to open Outlook messages stored in the file system
  • Outlook Folders Appear Empty after Exporting an IMAP Account
  • Browseforfolder_2
    How to use Windows File Paths in a Macro
Subscribe
Notify of
161 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
karthik
March 26, 2024 7:05 am
Dear Diane, Excellent work.
this is saving exactly 1 year's email, what if i want to save all the mails starting from the day1.
0
0
Author
Reply to  karthik
March 26, 2024 9:28 am
So it quits after saving all messages within a year? how many messages? There is not a timer itn it, so it might be quitting because of the number of messages and not all resources are released. That usually triggers an error though.
0
0
Pedro
September 27, 2023 3:49 am
Dear Diane, many thanks for this excellent Macro, it is working like a charm and it is actually very helpful. A question: is there any way to automate the process, like running the Macro every time Outlook starts or at a certain time every day ?
Thank you in advance
0
0
Author
Reply to  Pedro
September 27, 2023 12:01 pm
Outlook doesn't have a timer, but you can use a reminder to trigger it.
https://www.slipstick.com/developer/code-samples/running-outlook-macros-schedule/
0
0
craig
August 31, 2023 5:51 am
I noticed emails with RE:[SPAM] do not save, can the code be altered to ignore the word [SPAM] to allow saving
0
0
M.Desnoyers
June 23, 2023 8:42 am
I tried to run this script and there is an "error message" "'76': Path not found." I tried the option "debug" and the line concerned is: "FSO.CreateFolder (StrFolderPath)".
Do you have a solution for that? This script could be so helpfull and great for me!! I hope it could work.
Thank you so much!
1
0
Long Le Duy
May 10, 2023 3:25 am
The above code runs ok, but if there is a progressBar showing the time of mail backup, it's ok!
0
0
aleks
December 21, 2022 8:28 am
Thank you for a very useful and smoothly running macro!
Love peace and respect!
0
0
Kilimanj99
September 14, 2021 12:58 pm
This script is great, exactly what I was looking for. Thank you! I will note I found 2 issues that I'll try to fix. You may already know about these. If you cancel when asked to select a save folder it will error out rather than handling the exception. If you select a folder in outlook to save and that folder is not a top level folder, ie InBox\NewFolder the script will error out saying the path does not exist. This looks to be because its trying to save in inbox\newfolder initially and hasnt yet created the inbox folder first so it cannot create the folder newfolder and thus it doesnt exist yet. Here's where that happens, I made a few mods so I'm not sure the line number, its around 40-45 and at this point strfolderpath = inbox\newfolder what it needs to do is create inbox then create newfolder in 2 seperate actions. If Not FSO.FolderExists(StrFolderPath) Then       FSO.CreateFolder (StrFolderPath)     End If Neither are a big deal to me, no impact, but thought I'd mention it. If you're looking for improvements it would be really cool if it gave a progress status of some sort. For me it just puts… Read more »
1
0
Tammy
August 13, 2021 10:21 am
How can I modify the above to get items off a Microsoft exchange server? Code works as long as its not in exchange server.
0
0
Author
Reply to  Tammy
August 14, 2021 9:22 pm
It should work with email in any account in Outlook. It won't work with Outlook on the web.
0
0
Gorgios
Reply to  Diane Poremsky
August 1, 2023 11:43 am
Hello Diane, I have the same problem as Tammy. My outook saves automatically emails to a server and after a couple of weeks they're not automatically visible in the folder. In order to see them I have to manually click on "click here to display more Microsoft Exchange elements" in order to see them (in each folder). So if I run your absolutely excellent macro in a given folder, I have 2 behaviours : if all emails are local, i.e. recent, it works perfectly find if there are some 'older' emails in the folder (i.e. available on the MS exchange server), it won't take them into account. Even if I have refreshed before by clicking on "click here to display more Microsoft Exchange elements" I guess there must be some sort of function/ sub/ procedure in order to simulate this click within the macro itself and hence get all emails. If I run the macro in a folder where all emails are old, and in MS exchange, I get basically no export at all. This is weird but very important for me to sort out, otherwise my export is missing a big lot of emails. Many thanks for your help… Read more »
0
0
Gorgios
August 1, 2023 12:24 pm
I have the same issue as Tammy. This macro is great and works just fine. But it only saves items considered as "available offline", i.e. not on Microsoft Exchange server. Those are not saved (although they are here).
0
0
Gorgios
August 1, 2023 12:30 pm
Hi Diane, thanks this macro is really great. But I do have the exact same issue as Tammy : it saves well all offline mails, but not those which are stored only on the MS exchange server. Is there a fix for that?
0
0
Gorgios
Reply to  Tammy
August 1, 2023 11:44 am
Hello Tammy,
Same problem here. Did you find a solution?
0
0
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
